Struggling with usability - planning, editing, conceptually
Howdy. Sorry for what could be a thread best served as a support ticket…only I am struggling with Xert. Across more than one facet. And wondering how others have gone with solving for this (as I’d like to unlock the knowledge behind it, not simply write off the sub).
  • training: the planned week ahead used to look at all my historical data (and I uploaded years on years worth) and know the plan bigger days on the weekend. Nothing large on a Monday, etc. Now I have rest this Saturday. Low endurance Sunday. And a sprint workout on the following Monday? Before considering today (work day, office job) is a 300+ XSS day?! Screen cap upoload.
    To say nothing of the fact I have a few broken bones (crash) and some other health issues I tried to have the platform and training account for…it couldn’t. At least not that I knew how. My threshold power has dropped a little. But nowhere near to what it would and is realistically at present.
  • editing: adding an XSS score to a ride without a PM was previously hard. Now it’s downright impossible. When you get on the one page (training) where you can edit the ride and pop up the box to add the score, simply clicking on the box closes it. Madness
  • AI predictions for performace. Heard Jack Burke mention this on his podcast multiple times. The pod is the reason I am giving Xert a go. For the life of me, cannot locate this feature?
  • Training Loads. Fitness Signature. And other Xert nomenclature. I am coming from Golden Cheetah and thought I could wrap my head around these terms easily enough. Not the case. And not really finding the vids all that helpful. Is there a Dummies Guide I am missing? Because if there is, would have loved it in the unboarding.
Sorry for the moaning. By all means roast me for dumb stuff I am missing. Just feel like I am missing a trick of three with Xert as it presently stands.
While some content is outdated you should find my newbie tips of value –
Onboarding steps for Xert trial users and newbies - General - Xert Community Forum
I can circle back to address some of your other questions after my ride today.
If your rides without power include HR (and preferably cadence too) you can enable HRDM under Profile Settings, General tab.
There is a massive glossary that explains many of the nitty-gritty details but I hesitate to send you there. :slight_smile:
Loading long time history is helpful to review past activities and trends but Xert works fine with several months of activities as long as they include some activities with maximal efforts along with a few BTs (breakthroughs).
When recovering from illness or injury there is no need to create an XFAI plan.
Switch Program type to XATA Continuous (blank calendar), set IR (Improvement Rate) to Maintenance or even Off-Season, and simply ride as you are able until ready to resume normal training.
Some odd things I notice are 9 hours on March 27 and 12 hours on March 31. Are those numbers correct?
Xert is going to apply recent history to recommend future activities. For example, what you normally ride on Wednesdays.
You can configure a weekly schedule by your Availiability under Profiles Settings, General tab.
You can change this at any time and recast or update a plan (if a calendar based forecast is in play).
The magenta matchstick on April 1 indicates a broken constraint that is also noted by the red dot warning in the Adapt Forecast button above the calendar.
You can investigate why by viewing the forecast chart on the Trainng page and hover over any matchsticks with a magenta outline. A text message will be displayed.
I believe the multiple activities/Modify bug as been reported.
What happens if you change Planner Settings (gear icon) to stack the days on the calendar instead of summarizing them?
MPA drawdown is key to performance prediction in real-time or in post analysis.
If you have a Garmin this function is evident in various data fields including MPA, TTE/TTR, Magic Buckets, and Xert Dashboard.
You also see it in action on the rainbow gauge when monitoring a workout indoors on EBC (iOS or Android app) and the gauge on the Remote/Session Players.
Thanks for the reply.
March 27 is odd, it’s counted a commute as a 10hr ride (instead of the moving time of 45 min). Deleted. But it’s done the same on March 31st. So this could be a bug.
Already tried the Adapt Forecast (clicked on it) two days ago. But did not do the rest. In large part because of the previously mentioned lack of knowledge and onboarding around all this.
Stack ranked the activities and that does allow me to add XSS…only they still count the commute as the time for me pressing start to stop. Which I keep across the whole day. Seems I have to split the rides up now? Lest Xert think I have 10hrs 3-4 days a week in the working week to train… sigh
What type of device do you use that you like to keep it recording all day long?
I would definitely consider a commute as two separate rides but if you prefer otherwise go to Profile Settings, General tab, Activity Time Method and select the option you want Xert to use.
To be clear, the setting Ridgerider is suggesting changing lets you use “moving time” or “pedalling time” instead of “elapsed time”. Xert defaults to “elapsed time”.
Thanks. Have changed to moving time. A little insane that it does not auto default to that
Many people (most?) want to know how much time they need to allocate for training, including stops, hence Total Time is often the best for planning. If you’re using Moving Time with outdoor riding, you may have to do some mental math to adjust for stops.
This is my single biggest gripe with Xert, probably the only one really. Currently recovering from a hip replacement TP was 255, FTP 245. I was comfortable with both numbers. Three weeks no riding and gentle work for the past two weeks. TP has dropped to 230.
I manually set my FTP to 200 then to 210.
Apparently Xert sorts it all out. No it doesn’t. It can up everything with a BT but it doesn’t lower anything…
All I was hoping for was the platform to understand that my commutes are not a 10hr training day. But that didn’t happen and it began to think I am rocking 10hr days midweek. Work around is breaking the rides up. Which is a tad frustrating and something I’d hope ML could account for. This is not a shot at Xert per se, this is clearly a weakness with ML in general.
Wondering please if you assist with one of the other questions, related to the performance AI tool that Jack Burke has mentioned across his podcast episodes. But that I cannot seem to locate?
I believe he’s referring to the Race AI. You can find it under Program - Forecast AI Race - Analyze a Power File.
You upload a fit file (with power data) and Xert analyzes the effort and training needed to match the performance in the fit file.
I have never understood why people would combine commute to and from work into one ride. You have 6-10 hours between the rides, and it doesn’t really make sense. You will be fully recovered after that time. The only reason to do it is to reduce the number of activities in your feed/calendar. I would say — if the break is longer than the ride, then it is probably a new ride :wink: if you change clothing and take a shower, it is probably a new ride.
I also take breaks on some longer rides, but the it is 10-30 mins to eat or take a ferry for a 4-5 hour ride.
Give us the choice. I want to know how long I need to ride for, not how long to sit at a cafe.
Couldn’t you use ‘Moving Time’? Is that not what you’re looking for? Maybe I’m misunderstanding?
I’ve never understood why people think what they do should be the experience for all. But that’s just me.
My commute is barely 14km, there and back. Sorry but it makes total sense to leave it as one ride. Physiologically it’s basically the same and makes life easier from a data point of view.
You do your 7km ride to work, work a day, the ride back, and that’s one ride?
What did you have for breakfast over the course of 12 hours?
Sorry? Not sure I understand? Why would I not eat across the course of the work day? My work commute is me riding incredibly slowly (which I secretly love doing, not always jamming it on the bike is quite enjoyable)
I’m saying you have breakfast and then lunch and then dinner. It’s not considered one big meal. Just an opinion but I find it bizarre to have two rides separated by 8 hours crammed into one ride.
Sorry, but even if the analogy held here it’s a ride - as noted - at a very slow speed. There’s no reason to not leave it as one. Strava can work out it was only a 45 min ride. TrainingPeaks etc can work it out. Xert instead thinks I’ve done a 10hr day.
How data is presented should be easily accommodating for something like this, given how many people commute. Slowly at that.
We provide 3 options to how time should be counted:
  1. Total Time
  2. Moving Time
  3. Pedaling Time
Most would expect to plan their training arount Total Time. If you have 10 hours to train and plan on riding outdoors with longer breaks / coffee stops then you’d want to include these in the 10 hours of available training time you have.
If you prefer to train indoors and sometimes do rides outside, Pedaling Time is likely going to work ok too since it’s more efficient to do 2 hours on the trainer and if you want to do 2 hours outside as it if was on the trainer, then you should use Pedaling Time since this creates the right comparison.
Moving Time is there since that’s what most people expect but it not the best metric for planning your training TBH. Historically it’s been problematic with using older metrics like TSS since it increases when you’re not pedaling or stopped and accounting for the appropriate amount of non-pedaling TSS has never been consistent. Most just stick with using moving time for TSS but that just makes the best of a bad situation. You should not get any credit for doing nothing or even get more credit the more of nothing you do.
So choose which one you wish to use but be aware of their limitations. As you can see from the comments, there are many fervent opinions out there.
