HOW TO: Adjust Forecast Around Preferred Workout/Activities
In this thread, I’ll guide you through the process of incorporating your favourite workouts or activities into your overall Forecast AI training program. Xert offers the flexibility to adapt your training program to accommodate the activities you want to prioritize, whether it’s group rides, virtual races, or beloved workouts that deviate from the original Xert Forecast AI recommendations.
To adjust your program around your preferred workouts or activities, follow these steps:
  1. Start by navigating to the day you’d like to schedule your favourite workout or activity on the Xert Planner. Hover over the Forecast Placeholder and select the ‘Choose Training’ option. Avoid using the ‘+’ button - that’s reserved for additional training on top of Forecast recommendations.
  2. The window will display the original Forecast recommendations for that day, but you can disregard these since you’re planning to schedule something else. If you have a specific workout in mind, use the filter or text search to find it. Alternatively, you can use a past Outdoor Ride or Virtual Ride as a template for the duration, distance, and XSS of your upcoming activity. To include older activities (>3 months ago), disable the ‘Recent Only’ option in the filter menu options. You can also manually input the predicted XSS, Focus, and Specificity using the Manual Entry option. In this example, I simply picked an old ride that I’d like to do again:
  3. Once you’ve selected your workout, activity, or entered the details manually, use the ‘Pin’ option to pin it to your training forecast. Keep in mind that your planned activity may not perfectly align with the forecast placeholder and may appear coloured Orange or Red. This will be addressed later. Pinning the activity signals to Xert to adapt the rest of your training forecast around it.
  4. Finally, click the ‘Adapt Forecast’ option and Xert will modify your training plan accordingly, considering the pinned activity. After saving the adapted forecast, you should notice that Xert adjusts the forecast such that I’m blue status (fresh) before starting the activity - if possible - and the forecast placeholder now shows a green circle:
We hope this guide helps you seamlessly integrate your preferred activities into your training program. If you have any questions or encounter any issues, feel free to ask for assistance in this thread!
Read More
Potential Issues to Consider when Modifying/Pinning Activities to Your Forecast:
First, consider the impact of continually choosing workouts that might not align with your overall program goals, even if you like them. If you need to train your Peak Power (as a sprinter) but you keep doing non-sprinting high-intensity workouts that keep you in yellow status and prevent you from being fresh enough to sprint, it may no longer be possible to achieve the required improvement in Peak Training Load your Forecast AI training program requires
For athletes using XFAI to train for a target event, be cautious about pinning activities too close to your Target Event Date. As you approach your event, there’s less flexibility to deviate from the Forecast AI Recommendations. Deviating too much from your forecasted training could impact your ability to arrive at your event with the required freshness. For example, scheduling an intense workout the day before a critical race might affect your performance negatively.
For example, if I try to pin an all-out 30-30 workout the day before a Target Event, Xert throws the following error: “Could not create taper week” :
Is there a way to do this recurring? It seems that needs to be done individually every day.
ty!
Not at the moment - something we could consider though!
FWIW, I usually sit down maybe once a week and plan just the upcoming ~7 days since I don’t know what I’ll be doing much further in advance than that anyways. You can try using that approach and see if it works for you!
Will the Forecast AI recalculate the future sessions as you complete sessions, or will you have to force it to recalculate by clicking the Adapt Forecast button. For example, if I choose to do a workout on a prescribed rest day, or I do a workout with different intensity vs. prescribed, won’t it be appropriate for Forecast to readjust future workouts?
You will need to use the ‘Adapt Forecast’ button for that.
We thought about automating this process, but we were worried (from some initial feedback) that some users would be very frustrated if they spent the time planning out their workouts for a few days (or a week), then uploaded an activity and all their planned workouts were suddenly removed because of the updated forecast.
very helpful. I followed the instructions, but after pinning the activity (long zone 2 ride) and hitting the “adapt forecast” button the activity is still red and I still have a long zone 2 ride forecast in the same week. have I missed something?
Awesome.
Did you ‘save’ the changes after adapting? Clicking adapt will propose the changes, but you’ll need to click the ‘Save Forecast’ option to actually save the proposed changes.
perfect. thank you. babe that goes without saying, but might be worth adding into the original post. it’s easy to get overwhelmed on here…
thanks again! I think this will really help
I know that i have strength training on the same two days each week. Would prefer if the planner could automatically incorporate those (i.e not show HIIT as recommended for those days)
I thought the latest recommendation (or fad?) was to do your gym work on HIT days. :smiley:
Hi.
The mechanism described in this thread is great.
But it has one key downside:
  • I have added a selected workout in the planner, pinned it and until then it is ok.
    Given a morning - the pinned workout is in the planner and as a suggested workout.
    However, it is removed when any activity is performed.
    For example, I have cycling workouts set for the afternoon hours. In the morning before work a longer walk with the dog, going out to get bread - this activity registers in ‘GarminConnect’ which is synchronised with ‘XERT’.
    And here we come to the described ‘minus’.
    When such a morning activity is synchronised with ‘XERT’, the cycling training pinned in the planner for the day is… deleted :confused:
BTW - creating a profile other than cycling will not find use with me, I do not need it as a matter of principle.
I have the exact same issue, walk the dog and record the walk, the rest of my days plans are deleted and the planner shows an angry red.
Hello,
I am looking to add some B races to my planner but have not completed these races before and have no idea what xss I will accumulate. The only factors I know are rough time and distance.
How can I add these correctly so that my plan will adjust around these events?
Hello,
I am still looking for a little but of guidences on this issue.
Hi Chris - sorry I missed your earlier post!
If you have any previous events (even training rides or races) of similar duration or intensity, those can be a helpful reference point. Are these upcoming races gravel, MTB, or road/crit events? That can also guide how the XSS might be distributed across Low, High, and Peak.
One way to estimate the XSS breakdown is to use the Event option of Forecast AI (without saving the plan) and experiment with different event types, terrain types, & estimated durations. This can give you a ballpark estimate for the Low/High/Peak XSS values you might expect from similar events/races.
Once you’ve got something that feels reasonable, you can return to your Training Plan and add the Low/High/Peak XSS for your races days using the Manual option of the recommended training modal. Input your estimated XSS values, pin it, and then hit Adapt Forecast so your plan adjusts around it.
Hope this helps!
Both races are road races but in the future some gravel races will be introduced into the calendar.
In that case, I would experiment with the EVENT option of Forecast AI and adjust the race type, terrain, and estimated duration to get a rough estimate of Low, High, & Peak XSS.
You could then pin those estimated Low, High, & Peak values into your fitness planner for the respective races, Pin, & Adapt around them.
