I know populating the Planner sounds like a good idea and many who arrive here from traditional planning platforms have the same reaction. However, it actually runs contrary to how Xert works best.
A week at a time is all you need to plan and even that isn’t required. You’ll understand why this works better when you become accustomed to Xert’s new way of training. It may take a couple of the phased progression cycles to fully appreciate the benefits.
Recommended daily workouts can vary depending on how you feel and which settings you adjust as you train. Changes may include dialing IR up/down, adjusting freshness feedback slider, workout filter selection, varying days per week, mixing indoor and outdoor rides over the week, switching athlete type, and how often your signature changes.
It may seem unnerving at first that you don’t have a filled out multi-week plan on a calendar, but rest assured one is operating in background through XATA and adjusting daily based on your activities and responses.
Consider that you are in charge of your weekly allocation including rest days, when to ride easy, long, outdoors, or test yourself, add more recovery, etc. You don’t want a pre-populated calendar for weeks on end emulating a cookie-cutter plan. Xert is a dynamic interactive method of training by power. That is a big shift compared to traditional multi-week plans.
The pacer needle shows if you are on track. 11am-1pm is an ideal range, but no need to worry about making up a deficit or carrying a surplus as XATA absorbs any difference during it rolling seven day cycle. You can be up one week and down another but still on track for phased progression or maintain fitness at a desired training load level.
Coaches may populate the calendar for longer periods when they have specific goals in mind for clients. Also note the preferred method of populating the planner relies on selecting past activities and favorites with drag and drop. That’s best determined over time as you move through the phases and learn the system. Then apply what you’ve learned if you’d like to structure and plan your week ahead.
So in summary XATA is your day-to-day “planner” and that plan can change at any time based on settings (athlete type, improvement rate, freshness feedback, target event date), how well you are responding to recommended workouts, which workouts you select, and what outdoor rides you do. Factor in scheduling conflicts, sick days or injury, weather, and life-just-happens events and you get the idea.
Best not to plan too far ahead.
Related posts --.
Fitnes planner suggesting same workout constantly - Support - Xert Community Forum (xertonline.com)
Event-goal: Auto-populated all suggested workouts in planner - Feature Requests - Xert Community Forum (xertonline.com)
Xert Training Pacer – Xert (baronbiosys.com)
Since your TED is set more than 120 days out that puts you in pre-base which means there is no specific guidance used for the focus of your training and the advisor simply offers a wider variety of workouts near your Athlete Type. XATA comes more into play once you enter Base phase with higher intensity workouts appearing in the mix at some point during Build. That is many days out from now unless you decide to shorten TED and move to Build which could be stretched out later by changing TED again.
OTOH you can’t go wrong with more base endurance activities.
Lots of newbie tips are in this post if you haven’t seen it already –
