Group ride on sunday
Hi
If I have a training session on Sunday and want to replace it with an outing with friends, what should I do?
That’s not what I intended.
I wanted to know what I should do if I just want to go for a group ride with friends without being involved in any structured training.
You can simply do the group ride and ignore the forecast.
Xert will analyze the ride and if the activity unbalances the plan a red dot warning will appear in which case you can run Adapt Forecast.
If you want the group ride posted to the Planner ahead of time and have ridden the route before, you can locate that activity on file and pin it to the Planner using the instructions I linked to.
In either case you are never locked into exactly following a forecast. It adapts to whatever you decide to do.
In other words, in the planner I leave it blank and then xert analyzes my return, right?
If the Planner shows a recommended workout that you never do, the entry disappears after midnight.
Or you can manually delete it at any time.
