Send this into support@xertonline.com along with screenshots of all your configuration screens. As well, provide details on what other apps are running on the Samsung or on your PC that might interfere with the connections.
I bought my first iPhone (13 Pro) and used the iOS XERT app with it (instead on Android) with exactly the same set-up as I described before, that originally worked with my S10 Plus smoothly until it didn’t.
No drop-outs. Everything works well now.
That’s a 1000 EUR solution, but at least, it is a solution.
You could go (and test) with an iPhone 5SE (of 2016) for refurbished at 70€.
Small 4" form factor. Still on the very latest iOS, still using all the new Apps.
I am certainly no expert for iOS, but I can say that you are wrong with this one. 5SE is not part of newest security updates anymore, since quite some time.
As I have a working solution now - I don’t need a second IPhone, and the display would have been to small for my old eyes. Thank you anyway.
It’s the iPhone 5SE (not S nor SE2) and it’s running iOS 15.4.1 at present.
Screen is small but’s it 's a good navigator device running a battery cover.
An older SE is what I use for testing EBC on iOS. Highly readable form factor.
No need to update the iOS version since there is no SIM installed and it’s not used as a phone.
Ditto with my ~$99 Android head units which include a KingKong Mini and a refurbished Palm. No SIMs but you can install and run any apps you want that don’t require a mobile connection. Google Maps works fine too (offline map mode).
I find it quite amazing that it’s still suported with updates, but the SE is really the last of the very last supported phone devices. The tech show’s it’s age, the camera is awful and the battery drains quickly.
I’ve to admit that i’m very tempted with the Hammerhead Karoo2. It’s no smartphone but uses a smartphone SIM card and (and!) runs Xert EBC natively on the device.
