Wrong MPA
Hi there!
I am having trouble with updating my MPA on the android app (MPA/Power) that I downloaded to my Garmin 830.
My MPA is around 700 and its shows 1200 by default, although I have done every step to update it.
I have done some outside rides and the dot is always yellow never turning green. The phone and net connections are good, so I dont know what the issue is.
Can you Help?
Regards.
See this thread for some things to try –
I’m using the “MPA and Power - Xert” on Garmin 1030 MPA always 1200 - Support - Xert Community Forum (xertonline.com)
Thank you for the tip!
Will do.
Best regards.
