Workouts confusion/question
Hi, I need help with 2 scenarios.
  1. In the [Planner], For the current day, shortly before I begin my workout, I manually select a suitable workout by cllicking the “+” sign and add it to the planner. Then if I start Zwifting, starting Magic buckets, the MB buckets are according to the workout.
    Question, how do I send this workout to Zwift so I can perform the workout AND use MB at the same time? I could not find any way to send this workout to Zwift.
  2. In the [Training], if I select one of the recommeded/suggested workouts on the right side, I can send it to Zwift, by clicking the send to Zwift button.
    'Question. How do I send this workout to the planner? If I send it to Zwift and start the workout, since it is not in the planner in the MB I get XSS from the remaining XSS field.
Today Xert said I am tired so the recommendation was Endurance, something like xxx | 0 | 0
I still wanted to do a pursuiter “Hard to breath” but since I couldn’t get it to the planner, the MB interface was the endurance, with only target for low XSS and nothing for High/Peak.
Basically what I want to do is to be able to select a workout, send the workout to Zwift, also get the workout in the planner. Then do the workout in Zwift and at the same time use MB with the corresponding low/high/peak bucket. Especially days when Xert says I am tired and should do Endurance, but I don’t listen and chose a pursuiter workout anyway :slight_smile:
Thank you
If you select a workout from Training page with Play Now, XMB will fetch the XSS target of that workout.
For example, recommendation could be Endurance but I can tap Filter to list whatever Focus Power workout I want and select an entry with Play Now.
Or I can go to the Planner, tap [+], and do the same with Select & Save.
If you want either option to show up on Zwift (automatically) as you select the workout, go to menu, Sync, Zwift, an enable Send Scheduled Workouts.
This works for Training page or Planner since technically Play Now is the equivalent of schedule this workout right now. :slight_smile:
Note: If you add a workout to the Planner and decide at the last minute you prefer something else, remove the entry from Planner and use Play Now from the Training page.
In recommended workouts, on the training page, I sometimes get recommended workouts I have done in the past, such as a pacebot ride with Maria in Zwift. I clicked on delete from the recommended list.
When I click on delete, does it mean that the actual ride I did also gets deleted from the activities list?
When I clicked on delete, a whole bunch of recalculation messages popped up which makes me worried.
The intention was not to remove any ride activities I have done. I just wanted to remove it from my recommended list.
I found out myself. They were actually removed from the activities list, so I had to re-sync them back. This is maybe a bug?
Recommended lists include Workouts from the Library plus Outdoor and Virtual activities from the past that meet suitability requirements.
By default, All three types are listed.
If you delete an outdoor or virtual activity you are removing that past activity on file. Your signature and training advice will be recalculated without that data.
If you did that by mistake you can import or resync the FIT file from elsewhere if the activity exists on another platform. For example, from Garmin Connect, Strava, or Zwift.
I’ve run into this myself. In this scenario, the user is expecting to not to have recommended a certain ride. This is a failure of logic. This is not the place to go to remove rides from your ride history. this is ONLY the place to go to remove recommendations for future workouts.
D
I tend to agree. I was suprised that the actual rides dissapeared when deleting a proposed workout
