Having followed XERT now for about 2-3 months of training, a few things have changed significantly from programs supplied by Trainerroad and Zwift.
One of them is very little threshold work, but a lot of significantly suprathreshold work.
The second is a large amount of time spent at the very top end of the endurance zone.
The ‘so what’s’ here are that mitochondrial endurance adaptations correlate with volume but do not correlate with meaningful intensity.
The conclusion they draw from the meta-analysis is that you should probably just work at a lower intensity for endurance.
What I mean by this is: 100 XSS over 1.5hrs is not the same as 100XSS over 2hrs. 100XSS over 2hrs is superior in terms of endurance signalling.
I feel like in XERT, the engine takes an “Area under the curve” approach. I.e. 100xss done in 90mins IS considered equivalent to 100XSS done over 2hrs - but this practice means I find myself more fatigued by my endurance sessions than I would like to be.
e.g. comparing two endurance workouts,
(1) Xert - Workout Details (xertonline.com)
vs
Have similar XSS, but if I asked you: which one would you rather do the day before Ronnestads, I think the answer would be clear.
In fact, this effect in the paper seemed relatively consistent down to pretty low levels of Intensity. They joked but suggested you might just be able to noodle about at like 100w and still get most of the adaptations.
I’ve started to find the high LTP workouts having a real impact on my level of fatigue - so I’m going to try and rebalance and do easier endurance and harder hard days.
