Indoor training without heart rate
Hi!
I would like to know if I perform my indoor workouts without a heart rate monitor, will this influence the Xert AI analysis?
Using only my wahoo kickr core.
Xert primarily uses Power data! HR isn’t needed - I know plenty of cyclists that don’t ride with HRM’s and use our system.
Thank you very much my friend.
I’m thinking about an Apple TV and because of the limitation of Bluetooth channels, I may sometimes not use FCR, like if I use Rouvy for example.
ATV is a problem with respect to the number of connections.
I am moving to a trainer with virtual gearing and that means loosing my HRM connection.
My workaround will be to record on my Garmin as well and upload that file to WKO5 or Intervals.icu.
The Rouvy or Xert ride will go to TP and Strava.
