When using Forecast AI you are assigned some XSS for each day. Before you do a workout you can get a suggestion on workouts to do to fulfill the XSS requirements for the day. However, if you do one workout that partially completes the XSS requirement, you must manually search for a workout covering the remaining XSS.
For example, I am assigned 218 XSS today and have completed 102 XSS, giving 116 XSS remaining.
When I open the Training tab, Xert will propose some additional training, but not the remaining training. As you see below, it suggests 215 XSS, even if I only have 116 XSS left. The high and peak XSS are too high to match the remaining XSS.
Wouldn’t it make sense if this tab instead suggested what I needed to do to do the remaining XSS (low, high, peak)? The Autogen could then also create a workout that matched the remaining XSS as well.
I created a workout that matches the remaining XSS very well, but it is shown as Unproductive, and it will therefore be shown more or less at the end of the list:
What do you think @xertedbrain ?
