Hi, I haven’t really looked into the beta yet—just skimmed through it. It sounds really good! However, I’m not entirely clear on the glycogen depletion aspect. Is this something you can opt to use if you want to fine-tune your training, or is it absolutely essential for the new system? If it’s the latter, that would be too complicated and time-consuming for me.
That would be a shame, as I actually like the system as it stands—with “Xata Continuous,” I’m able to approach things in a nice, relaxed way.
That is a good point, Harry. The aim is to set defaults well enough that users can run the system as-is with little adjustment.
Adjustments might be left to those interested in this analysis—and who wish to refine settings—as well as riders doing ultra-endurance events, where glycogen modeling matters more (depletion has little impact on rides under two hours).
Thanks a lot, Scott—that’s reassuring. I’d estimate that 95% of my rides are under 2 hours, so that should work out just fine. I’m really looking forward to it and hope it won’t be too much longer before version 2.0 is released.
P.S. The new XERT EBC beta app for iOS is brilliant.
I’m still trying to work out how to use this feature to find out how much CHO to ingest on my rides as there is still a lot I don’t understand about it.
At the moment after a ride I am altering the following:
I reduce the Muscle Glycogen Capacity (g) to 450g as that is my best estimate as the amount of glycogen that someone of my age and weight can generally hold in their legs.
I change the gross efficiency to 20%
I enter into the Muscle Glucose Uptake Rate the CHO/hr I have ingested on the ride based on total elapsed time.
I save it ,then look at the substrate utilisation and that is where I become unstuck.
MGUR is how fast your muscles absorb/uptake carbs, not how fast you eat them. You can input the ingestion rate, but your uptake rate could be higher since your liver will release glucose into your blood and you can convert lactate back to blood glucose too. But it could be lower also since your brain needs blood glucose and could be using up what you’re eating.
I know you’re wanting answers to “how much should I eat?” but that’s a different problem that can only get solved once you know how much your body actually needs first.
