Hi, in new to xert and just trying to figure out how everything works! Running on a full subscription rather than the free trial in case this makes a difference.
I’ve installed the xss bucket data field on my Garmin 840 & logged in via Garmin connect. when I do a workout, either through xert android app or in zwift with the Garmin simply recording the activity, I see the green dot appear and xss targets update on Garmin as expected. but then, no xss accumulates during the workout! What am I doing wrong??
Any help appreciated!
Hi @Jarlsberg, welcome to Xert!
Just guessing, but are you using a smart trainer as your power source? If so, be sure you also configure your smart trainer as a power meter in your Garmin’s sensor menu. That allows the XSS Buckets to access the power data & should resolve your issue.
Try that out and let me know how it goes! Cheers!
Gamechanger! Thank you sir, that solved it indeed, I had only connected the trainer to the Garmin, not the power output alone…
Much appreciated!
