I’ve managed to import a ZWO file successfully into RGT. The issue I found is that workouts that have a gradual power increase, start at the peak power instead of ramping up. For example a workout in Xert may have started initially at 120 watts, then progressed to 170 watt. In RGT, the workout stated at 170 instead of ramping up slowly.
Has anyone experienced this issue and does it also occur in Zwift?
Only Xert can do the curvilinear ramps. You’ll notice that exporting any of the XSSR style intervals will make them much harder in other platforms, since they’ll decrease linearly instead of exponentially.
The “best” solution would be to have Xert app control the trainer for the workout & have other platforms (Zwift, Rouvy, etc.) only connect to your power meter and record the power/cadence data and not control the trainer. Then you get all the Xert SMART goodness and curved intervals while still enjoying the visuals of another app. Cheers.
