Xert Segment Hunter feedback
download and install on garmin 520, pull segments from strava, jumped on the racer and drove straight to the segment area. Hunter started and it worked perfectly. Run two tests, one where I started below level and once I started above level, in both cases Xert Segment Hunter tried to adapt and showed me to the correct workload. I rolled home and was thinking about how little an adaptation in this app is needed to make it worth on recurring training intervals? #hint #gr8 #app
I.e. Smart workouts. :slight_smile:
If I’m on the start line of a TT but the physical start line is after the start of the segment, will the hunter still work?
