Have weird issue with xert player (see attached). Not possible to make it work stable with wahoo kickr core and edge 530. It was ok before.
Did the issue arise after a Garmin firmware update?
Are you sure no other apps are trying to connect to the trainer via BT or ANT+?
All devices have bluetooth off. I did wifi analysys and have strong signal on ch11 from few routers. ANT+ connection. And yes garmin after last update.
Hi @faraday! Send a note to support so we can take a look into it. Include the details about your setup (power meter, etc.)
