Xert estimated Threshold 20 watts too high!. Please Help
Hi there.
I did a short effort, 3m+ at 350w and Xert recalculated my signature pretty bad. There are no issues with power meter. I would prefer if the fix wasn’t a “hack” like flagging the ride, there’s nothing wrong with the data, the issue is the algorithm.
There’s no way I could hold 285w for 30 mins or so. I did an almost all out 20m effort some weeks ago and I did 272w. With this Xert give me a Threshold estimate of 266w, which is appropriate.
@ManofSteele @xertedbrain Please help!
Hey @oldandfast Welcome!!!
What’s your signature? There might be an imbalance the algorithm didn’t see in your data.
Hi Armando,
These are the numbers:
Thanks!
Your PP and HIE are quite low. Often a PP that’s too low can cause TP to get inflated especially when a breakthrough is from a constant effort nearer threshold that doesn’t exhibit a fatigue pattern to express your PP or HIE… You can correct this by adjusting your PP manually and re-extracting the signature. If you’re not sure, reach out to support and they can help with it.
