I am not sure if this is possible or not, but hopefully I can explain what I want to do.
I want to do a breakthrough attempt next week and rather than doing one of the breakthrough tests I thought I would try to achieve this during a Zwift race - or one of the Tour of Watopia events.
If I just ride as hard as I can for the duration, i will have no idea if a breakthrough has been achieved until it’s over.
I wondered if it was possible to get the remote player running within Xert to monitor the activity in Zwift (so receiving data & analysing it), but not controlling the trainer.
Then I can keep an eye on the power dial readout (not sure what it’s called) and see where my pink MPA line is, to hopefully push for a breakthrough.
Is this possible? The best way to do it? A stupid idea & would be better of doing something else?
Any advice gratefully received!
Not sure this will do what you want (I’m not a Zwift user) but it sounds possible with a combination of ANT+ and BLE along with the rainbow power gauge pop-out –
Sounds like I need to run Zwift as normal (let Zwift control the trainer).
Open the EBC app, make sure trainer control isn’t applied and then load up a free ride workout.
This should then let Zwift and my pc control the trainer and Xert effectively just displays the metrics.
Zwift is all ant+ on pc, then xert is android with power-only via Bluetooth.
A few points,
workout selection doesn’t matter.
don’t accidentally turn on trainer control on the android while in zwift, as sometimes zwift won’t regain control properly without a zwift reboot.
set zwift in windowed mode, then open a browser and pop out just the gauges. I zoom on MPA only, and normally move it a little left to see power ups, then activate powerups using my phone:
I have an old Android phone on my handlebar that I used to run EBC. Works quite well and can give you the same information. Others use an old iPhone or maybe even a small Amazon tablet
