Last couple of days, my rides on my Garmin headunit / Garmin Connect are not appearing in Xert. I tried to reconnect the account under Sync → Garmin Connect while logged in to Xert, and got the below error…??? My account is paid up and active…
Hi David, sorry you’re having troubles. This is an error on Garmin’s page, not on ours (check the URL). You can try using another browser to reconnect - that often resolves the issue. HTH!
Thank you for your tip.
I used another browser beside safari (Brave Browser) and the issue was solved.
