title says it all. I can get Basic data and Power Duration screens, but when I click on Advanced MPA, the screen does not change from the display showing Basic. Any thoughts as to why?
TIA, Anthony
Unless you had a breakthrough, I don’t think there will be much if any change between the two screens.
Hi Anthony!
The only difference between the two is that Advanced MPA allows you to manually edit, refresh, and extract a signature. It shouldn’t really be necessary to use it.
Carmen, Scott… thank you all very much. I reckon I’m “overthinking” it. Good to be back on the board. Best of holidays to you all.
Anthony
