I’m new to this, and have been using this to push workouts to zwift. Friday I did the suggested workout with no issue. On Saturday, I had it generate an AI workout and performed it with no issue. Yesterday I had it generate another AI workout and pushed it to Zwift. When I logged in, it showed that new workout in my list. But when I selected it, it pulled up the previous workout from Saturday. I tried loading it anyway, and it was still the wrong workout, and I tried restarting everything and still the same. Is there something I might be doing wrong, or something I can do to fix it if this happens?
Do you have Sync Zwift configured along with Automatically Schedule enabled under Planner Settings?
Or are you manually pushing the workout to Zwift from the Training page or Planner with the Send icon?
Yes, i have the sync set up and it automatically schedules the workout. I have altered the scheduled workout to an AI generated workout on Saturday and then again on Monday. But it seemed to work ok on Saturday. And yesterday the Zwift homepage was showing the correct workout, but when I actually opened it, it took me to Saturday’s workout again.
You can go to Sync Zwift and remove entries if necessary to ensure the WOTD is what you want.
It’s even showing the correct workout in Zwift when I log in, so the communication between the two is happening, but when I open the workout, it pulled up the previous one I had already completed.
Known issue with Zwift due to the same workout name. Try renaming it before sending it to Zwift. Or remove it from Zwift first.
Thanks. I actually wondered if that might have something to do with it. I’ll keep that in mind.
Quick way to remove is Sync, Zwift, Unschedule from XO.
Is it only an issue if it’s the same name as the previous workout, or any workout uploaded before?
Same name such as “AI Generated Workout” but that isn’t likely two days in a row.
With Automatically Scheduled enabled there should be a suitable selection from the recommended list each day along with some alternates.
Autogen is typically run if there isn’t a suitable match you want to ride or you want a simple workout to ride outdoors that meets the day’s strain goal.
