ebaldo
(Enrico Baldisserri)
February 20, 2023, 1:46pm
#1
Hi,
I try to make a workout in my trainer Garmin Tacx Flux2
AppErt connect the smart trainer all is ok… the icon of trainer is BLU and ok.
But when I start to ride the speed and distance and power (watt) is not setted by trainer … only time flow:
What can I do ?
Thank you in advance
Enrico
PS
Note that other APP go well … like for example Garmin Tacx, Trainerday o TrainerRoad.
ridgerider2
(Ridge Rider2)
February 20, 2023, 2:04pm
#2
Is Speed from Power enabled under Sensors?
ebaldo
February 20, 2023, 8:24pm
#3
Fantastic!
Now I set all sensor all is ok but no the distance
I made a 45’ workout … I got power I got average km/h but not the distance
How can I have also this metric ?
Thank you
In advance
Enrico
ridgerider2
(Ridge Rider2)
February 20, 2023, 8:43pm
#4
Make sure no other apps are running and connected to your trainer.
Under EBC Sensors you need –
Power paired to trainer or your power meter if you want Powermatch enabled.
Trainer Control paired to trainer.
Heart Rate to HR monitor.
Cadence paired to trainer or power meter.
Speed set to Speed from Power.
Make sure all sensor settings you configure turn to blue.
You can test them from the Indoor Sensors page.
xertedbrain
(Armando Mastracci)
February 20, 2023, 9:10pm
#5
Be sure you tap each one in each section and see that it turns blue and is connected. You should then see power data showing as you pedal.
You can also look to see if there are firmware updates for the trainer.
Be sure no other apps are running.
