Syncing activities
None of my indoor rides are showing when I sync my historical activities. All other activities are showing. I have used both Zwift and Rouvy during this time
I assume you are syncing from Strava – Xert - Connect with Strava
Make sure the edit list looks like this and only this for your cycling profile.
StravaSyncCycling
Then enable Sync New Activities from Strava.
Select or set a custom date range. For example, last 90 days, Show 100.
Tick Start Date box to select all entries listed.
Then Sync button in bottom right.
If still missing entries you could try adding Workout to list then repeat the sync step.
However, you only want cycling data in your Cycling profile.
If you want other activities such as running, setup a separate profile for that, select that profile, and follow the same sync procedure for running activities.
Add Profile is a dropdown option when you select your account name in upper right.
