I have synced last year history of workouts and observed my TP decrease. What gives?
Hi Aldar, you’ve got a faulty ride in your progression that may be causing some issues (10 Mar 2018), you may want to remove it. However, it looks like your training load and TP are tracking quite nicely. When you load older data into the system, a trickle-down of all activities since those activities occurs. With your decay setting at optimal decay (the default setting), the system learns how your fitness parameters change with training and adjusts the newer activities/fitness signatures in response.
If you feel that these values are too low, you can aim to reset them via a breakthrough. Hope that helps! Cheers
Ahh. Thank you!
