Where can I find the exact starting date as used in “Goals” (yellow highlighted below)
And does it reset to the actual date every time I push “Update Advice”?
In my testing it appears to be stuck on the Starting numbers that correctly reflect 120 days prior to current TED.
However, the values don’t change when I alter the TED.
Recent update bug or something else at play?
Thanks!
How did you test/determine the starting date?
I cant seem to find it anywhere in the system.
My current TED of April 17 was set back in Dec, so I dragged the XPMC chart pointer back 120 days and the numbers coincide with that date (Dec 18).
But shouldn’t they change if you edit the TED? ![]()
