Hello, i have a Drivo 2, and i use Xert android 3.4.4. What is the difference between in options with speed from power and speed from DR (home trainer control) ? What is the better ?
Could you explain the red zone and yellow zone in options Xert android 3.4.4 ?
Thx.
Hi Nathan,
Speed from Power is the recommended setting for Xert Mobile on Android (and iOS). Using speed from a trainer doesnât make sense, since the speed/distance will only be dependent on the gear that your in (and your cadence), not the effort that youâre putting out.
Speed from power calculates an estimated speed/distance based on your weight and power output, so it will likely be more reliable and closer to what you may have expected to ride outside, given that same effort. Hope this helps!
Hi Scott,
Any update on the excessive speed on the android app?
Maybe not excessive, just optimistic
The fix has been added to our 3.4.6 build. Should be available soon.
Thx for your explanation for the speed from power. But Could you explain the red zone and yellow zone in options Xert android 3.4.4 ?
compared to my normal outdoor speed itâs really excessive. Compared to everyone else itâs optimistic
Orange zone represents power outputs that will result in failure within 3 minutes
Red zone represents power outputs that will result in failure within 30s
Purple zone represents a BT!
Youâll notice as you work above TP, the Orange, Yellow, and Purple zones will start decreasing (along with MPA).
Currently âSpeed from Powerâ is more like this:
Than this:
Somewhere in between should work fine.
I guess overestimating is better than this, I suppose?
Ha! Thatâs on my turf. Dutch mountains
The beta for 3.4.6 should be (fingers crossed) pushed out to Google Play store by the end of the day. Still doing some final testing here
Thatâs excellent news Scott. Thanks for this. You do realise that Iâll be complaining that Iâm too slow now
I guess weâll start prepping 3.4.7 already ![]()
Hello, cool for the 3.4.6 update version, iâm beta tester !
Chapeau to your developer. He seems to be highly skilled and productive.
All our developers are amazing! They do a great job.
btw, version 3.4.6 has officially been pushed into Beta to the play store. Just waiting on Google to review & publish it. Should hopefully be available for you all soon!
I did a test with that build yesterday⌠easy, 1 hour ride put me right at about 30km, seems close enough for me.
Sounds perfect Scott thanks.
Cool 1 hour ride put me right at about 24km, seems close enough for me.The beta version 3.4.6 is cool for speed.
So the Kickr Bike does not use gears to calculate, you can change your gears and cadence all you want but your speed will basically stay constant based on how fast youâre turning the flywheel. I found that the discrepancy between EBC and the bike itself is around 1.5mph, EBC being faster. The EBC number seems to be more in line with what I could produce on a flat with that power so Iâm assuming that the addition of my weight is a good factor.
Since youâre riding in place, hard to say which is ârightâ⌠every app has their own calculation! We just recommend using Speed from Power in EBC when using our app for best results.
