I tried to use the Android app for the first time. Using an older Samsung phone, no problem to pair a Wahoo Kickr (SNAP) and a bunch of other sensors via ANT+.
Speed display in the activity was all over the place, causing a bogus distance. I tried to fix this in settings, but a) it’s not clear what units wheel size needs - and I have standard 28x700c tires so it shouldn’t have been so far off in the first place b) Making the number very big or small seemed to have no effect! c) Switching speed off in the ANT config of the trainer and enabling speed from power also gave very high bogus values.
Now, afterwards, I can see on Strava that a while after I stopped trying to fix this, speed values became normal and reflected correct speed from power, which I left it in before giving up. So maybe I can just leave that and the problem is gone for me after half an hour of frustration.
But this doesn’t explain why the display in the app gave bogus values and making wheel size very small or big had no effect. Do the settings take a while to activate or something?
Second problem: the HR displayed in the app is wrong (and presumably, what it records in the FIT), offset by about 3-4 bpm too low. It’s not lag, it’s a fairly consistent offset. As if some scaling factor is wrong or a rounding error in the conversion. I am fairly sure Xert is wrong here because I had the live display on the watch that was broadcasting, and I have used the same setup with TrainerRoad which matched the watch display exactly.
