It’s completely unclear what the proper settings should be when using the Xert Player for actual (not trainer) road work.
What do options these options do and how should they be set?:
GPS Enabled
Logout
Reset Cadence Optimizer
GPS Enabled
Logout
By default, GPS is disabled for workouts. Use this setting (or in the app) to enable it. Logout enables you to login again to Xert from GCM. Reset Cadence Optimizer is a feature reserved for support purposes. Aside from “Logout” , you can use the app itself to adjust all settings.
Thanks. Does this mean that GPS should be enabled for actual road work?
You’ll mostly likely want to get a picture of where you’ve been during the workout so I would say that you should enable it but it may not be important in the assessment of the workout.
