Is this new?
I’m intrigued, what does it do!!! I know I had to re-sync my Garmin yesterday per Xert prompt.
Is this new?
Disregard or merge, l found a new feature release thread talking about this.
I wanted to perform all training on garmin edge 530 and now I realize that this is not possible. Any suggestions or options how to export the training to the device ? In trainer road or training peak I have image of intervals. Here I have I believe quite good app but with no implementation on garmin? I tried on several workouts and “send to garmin” button doesn’t work.
Hi @mariuszuzd should be working just fine. Kindly send a note to our support team explaining what you’re doing (or what’s not working) and someone can help you from there.
In case it’s relevant I thought I’d just mention that the ‘Send to Garmin’ button does not send the workout to the Xert Workout Player App for Garmin. For that, you can just use the ‘Play Now’ option beside a workout to do that (or ‘Schedule’ the workout for a later date/time). The ‘Send to Garmin’ just sends the singular workout to Garmin Connect. From Garmin connect, you need to sync the ‘Xert Cycling Workout’ to your compatible Garmin Watch/Headunit. HTH!
Hi! thank you for your quick reply. After several “clicks”, finally the training appear in the garmin connect in the trainings, so thank you, maybe I wasn’t patient but I thought that this will happen quite quick. However, have a look below. I have no garmin button any suggestions ?
Garmin has a 50 interval limit, unfortunately.
