I’m trying to fall back to a simple setup using Stryd and the Garmin displaying Power in a field and having the MPA/Power app of Xert.
I used to have this working but I can no longer get it going.
the “Stryd Zones | Data Fields” ConnectIQ app is installed and the Stryd pod connects.
When using the ConnectIQ data fields the power from the pod shows but only if I use the connectIQ data fields of Stryd not if I use native data power fields or the Xert App.
I don’t use the Stryd running app with the workouts, … on the watch.
in the instructions for Xert I read:
Connect your Stryd to your Fenix, Forerunner or D2 watch as power meter
I did, but it doesn’t seem the matter how I try, I can’t get it working anymore.
I use the ANT+ connection , not the Bluetooth. Maybe the key was there?
Nope, doesn’t work. It is also very resource hungry for the watch. Can’t get it combined with core anymore either.
What I haven’t tried is to connect it again as bluetooth, but that’s agains all advise of Stryd.
Or remove all connectIQ apps and reinstall them.
Time consuming and frustrating activity
