Hi,
Ivve had a break and will be restarting. Is the best way to run a Xert workout via Rouvy, or via EBC, or is the no difference? I know that there have been updates to the way workouts are sent to Rouvy.
It would be easier for me if everything was on Rouvy, and I did not use the EBC, but, I want to use the full benefit of Xert.
Thanks.
On the Today page scroll down to Workout Players and enable Rouvy.
Rouvy fetches the workout of the day assigned to the Planner or selected on Today page which adds it to the Planner.
You’ll still want to use EBC on occasion if you’d like to ride some SMART workout as they are designed to work.
You’ll also want to use EBC if you plan to free ride on Rouvy with Magic Buckets.
Details at: Xert + ROUVY Integration – Knowledgebase
Thank you.
I’m returning to cycling after 5months off. So all of my stats on Xert will be wrong.
I am looking to Xert to self correct and not kill me!
With this knowledge, will it be ok running a Xert workout from Rouvy, or best to do something SMART on EBC?
Thanks for the guidance
To start back in you could ride easy base hours for a couple weeks. RPE rather than watts.
Main concern is whether TP is within an effective range when ready for HIT workouts.
How much did signature decay since your last activity on file?
Or go to Xert - Settings and Recalc from Last BT at Optimal or Aggressive Decay and compare the numbers.
You could also enter starting values based on lower historical numbers on file.
