Hi,
I want the Workout Player to control my trainer (Elite Drivo) but use my powermeter (Stages) to report my power/cadence and as a base for adjusting the resistance of the trainer. What settings should I enable on the Scan page for my devices ?
- For my powermeter I enabled “Power” and “Cadence”
- For my trainer, I enabled “Trainer control”: should I also enable “Power” (don’t think so ?) and “Powermatch” ?
Also using Xert in conjonction with Zwift, and both set to use my powermeter as the power source, I have a difference between the power displayed in Xert Player and Zwift, Zwift reporting about 5-10% more at any time… which made my first workouts impossible to finish :’-( At some point I played with the “Trainer power scaling” and set it to 0.95 which seemed to correct the problem; now I see that this value has moved to 0.96 and the “Trainer power offset” is now 2.28, are these values automatically modified ? Should I do manual corrections/calibration ? I don’t want to fail my next workout once again !
