Pin swapped days in Forecast AI
Hi, when I create a forecast plan and want to change the days, there’s always a red dot on the “adapt forecast” button. When I press it to update the forecast, it keeps swapping the days.
I know I can pin workouts, but it would be great if I could also pin the days themselves after I’ve moved them, without having to plan a workout first.
Red dot indicates one or more broken constraints.
What does the warning text indicate when you hover or tap any magenta outlined matchsticks on the forecast chart?
If an availability issue you can either ignore the warning or edit availability on the day(s) affected.
Ah ok, it was an availability issue. Then I‘ll ignore it.
Another question: Can I swap days in the mobile view. Didn‘t find a way.
