Apologies if this has been mentioned before. My peak power is 998 watts, however on my Garmin it says 1200 MPA. Should I change it to 998 on Garmin connect? Still a newbie😀
Be sure to update the Xert Code in your settings for the app(s).
Thanks. I have after every signature, but still remains the same. Do I have to manually change it to 998?
If the app is configured with the correct Xert Code, try and reset the unit. Alternatively, use Garmin Connect Mobile. Sometimes Garmin Express doesn’t always work correctly in configuring the apps.
