I am new to Xert and i am playing around for a while with syncing (Strava), uploading, different quantity of historic data and so on, to see wether this makes a difference or not. Just to understand the system. I deleted my activities in xert, did a new sync and even reset my account and initiated it new with the wizard. It worked a few times. And now: It does not sync anymore at the moment. It does not sync or calculate any activities, although the system found unsynced at Strava.
And anoter problem: Xert Player for iOS does not find my wahoo kickr core. Any other App does. I am using Zwift and i wanna use Xert player in combination.
The Xert Support solved my problem with the sync. Than you very much for that.
Unfortunately I still have problems connecting Xert Player iOS with BT to my Kickr core. A few minutes ago I testet connection with Zwift on my Lenovo with its native Bluetooth. Worked perfect. Power source, cadence and controllable.
Btw: I‘ve re-installed the Xert player app, using the latest kicker firmware and iOS 14.2. I waited apx 2min and always kept pedaling to ensure, that the kickr doesn‘t make any enegry save/sleep mode. I don‘t think it would but you never know
I assume you disconnected from this before trying to connect with the Xert app? Devices (trainers / power meters) can only connect to to one device (laptop, phone etc) at a time via Bluetooth, so if something else is connected to your trainer already, it can’t connect to anything else
The good News: I solved the Problem. While simply switching off/on Bluetooth and removing all other BT devices (ear phones, FR935, Edge etc) out of Reach does not help, I did the following.
Deinstalled Xert Player App
switched of BT
restarted the phone
switched on BT
reinstalled Player App
and ta ta ra ta … connected. Now imam a happy Sponge and I am looking forward to the improvements Xert will bring.
