I have been using the planner to plan for the next upcoming event (just completed last on 7th). Now I have moved the event date to next race on 11th and Adaptive trainer still has me in Peak phase for the next month. Is there any way to correct this as surely this is not correct?
According to the Program Phases that XATA uses ( http://baronbiosys.com/glossary/program-phases/ ), this is correct. If you would rather have one peak phase, then set your target event for your A race this year, and modify the Ramp Rate to taper your XSS requirements as you approach other B/C level races.
thanks!
