When using the XSS and MPA data fields on Edge, the MPA and threshold power are automatically updated at the beginning of the ride. In Karoo2, this does not seem to be the case. How can the value be correctly set up to have an accurate XSS value?
Thank you
Does the EBC app sync fine when you run that app on the Karoo?
