Magic Buckets (Endurance) three buckets?
I understand the fat bucket, but what are the other two buckets? The blog post is a little cryptic on this. In one post I read that the bucket on the far left is figured as time at LTP-10w.
Left is Low Intensity XSS where the target dot never exceeds LTP.
2. Zone XSS – This bucket shows you how much XSS you’ve accumulated in the ideal zone. You should aim to keep this number the same as the Low Intensity XSS number…
Looks like latest XMB version shows a colored bar on top of field indicating relative % of blue.
Indoors it’s easy to stay below LTP and get close to 100% in zone.
Outdoors is another story. :slight_smile:
What the’s ā€œidealā€ zone? How does it differ from the left-most box?
I just noticed the new bar above ā€˜ZONE’ and was going to ask what it meant?
Ideal zone % is 100. I.e. you spent 100% of the ride filling the Low bucket.
I believe the endurance ā€œzoneā€ is 75-100% LTP.
I got 96.7% yesterday on a recovery ride indoors just noodling along betow the target dot on the rainbow gauge. :smiley:
In @bother13’s example, 20.9/50.2 = 42% which indicates some time was below 75% LTP or above 100% LTP.
At least that’s my understanding at the moment.
An updated article is due out soon along with a how-to video which should clarify things.
EDIT: If you spend the entire ride within 75-100% LTP you’ll see 100% and a solid blue bar. If you spend any time below or above that ā€œidealā€ zone, the bar will show some black on the left (below) and some black on the right (above).
Ta!
I’m actually following an Endurance workout (No Time To Cry) but watching Magic Buckets on my Garmin just because…
Oops – meant to say below or above 75-100% LTP which is what blue to aqua to green workouts like No Time To Cry do.
Still a little confused by the answers, but I’m guessing that the far left bucket is all work under LTP, and the Ideal Bucket is work between 75-100% of LTP. By ā€œkeeping them equalā€, you manage to make all of the work done under LTP productive.
Far left is just total Low XSS. Could be done at any intensity from noodling at 50W to sweet-spot efforts just below TP.
Middle is XSS accumulated between 75-100% LTP. This provides a good balance between time-efficiency without being too strenuous.
Right is XSS derived from fat-burning. Usually will only be ~75% of the left bar, even if paced around 75-100% LTP.
The middle and right don’t really matter, but just gives more information and helps users effectively pace their endurance rides.
