Magic buckets 1st fetch gets overriden values, 2nd fetch gets original values
If you override the workout for the day by inputting manual XSS low/hi/peak, on the 1st fetch and ride, Magic Buckets gets the overriden values.
If you then save the ride, like at the coffee stop for an hour or whatever, and then start a new ride, Magic Buckets doesn’t get the remainder of the overriden values. It gets the original ride values, with what you’ve already done shown in there.
Today I had an endurance ride on the schedule, I overrode the values to do a ride with lo/hi/peak, and saved the file. Magic Buckets was on the 3 bucket screen. On the second part of my ride day, I was back to the original ride, with the Magic Buckets endurance screen.
Is this the expected behavior? Version 10.8 of Magic Buckets
The server should retain the override values for the day and reflect those on the second fetch.
Is it possible you filled the high/peak buckets before the cafe stop?
That would explain a change to the Endurance screen, but the Low XSS target should be the override number you entered for the day.
If the problem repeats I suggest filing a bug report.
Sadly no I hadn’t hit the targets. I’m sure I’ll run into this 2 files for the same day kind of thing, and if the problem repeats, I’ll file a bug report.
I just think if you’re stopping for a decent amount of time, just create a second ride instead of pausing it or letting it run.
