Magic Bucket settings
Hello. I was wondering what the “include FIT files” option does on the Magic Bucket settings
Hi @bikingviking , good question.
Enable FIT Graphs allows the data field to write some specific information into the .fit file that can be shown in the MPA chart for post-ride analysis.
The problem is that only 16 of these custom Connect IQ fields can be written in and there are many CIQ data fields that can write many things to the fit file, which can cause issues. So if you’re using Magic Buckets with many other CIQ fields (Moxy, HRVAlpha, etc) and having troubles, you can try disabling this setting.
If you’re like me and using only a few of Xert’s CIQ data fields, you can leave it enabled.
