After a hard ride today, a number appeared on the inner arc of the XMB (221 in the picture). I’m not sure if I’ve seen it before…
What does it mean? something related to the MPA?
Sorry for the bad picture, but I was ultra done.
Looks like you got a big breakthrough, was your old TP 221?
Yes you are right, my TP was 221… but the number changed from time to time. I remember seeing 260… so I think it’s the power of the actual time focus (based on the data before the BT).
Yes, that number is your MPA.
The MPA box will only show when your 5s power is >80% of MPA, so it’ll generally only show when you’re pretty close to a BT.
Perfect, thank you @ManofSteele !
If you tap the upper half of the screen to display the Summary page, what version of XMB is listed?
Current release is 2.7 (12 Mar 2025).
yes, it’s updated. version 2.7
I noticed a number appear there today. I think it was around 400 and I was in an interval so putting out 330 ish.
I also saw messages several times saying I was 30 seconds away from a BT. When you are gasping 30 seconds is an awfully long time !!
