Is there a way to limit the max duration of auto generated workouts
I’m often getting recommended workouts with ridiculous durations.
I rarely sit on the trainer for more than 90min with most of my workouts under the hour.
I have the WOD automatically added to my calendar, but I would like to see nothing longer than 90min for indoor workouts, is there a way to limit that permanently?
(Tried using the filters, but it does not stick)
No, that is not possible. But if you are always limited to 90 minutes you will probably find some good alternatives in the workout library.
That is linked to availability usually. Try setting availability to 1h or 1h30.
As @nebur86 suggests you need to configure Availability.
I just tested this by selecting the clock icon on the Planner for Monday and configured all Mondays to be 1 Hour, Fixed. Then I enabled Automatically Schedule under Planner settings.
Now suggested workouts on Monday are all around an hour (one of which will be selected after midnight).
Autogen also generates a one hour-ish workout from the Training page.That workout won’t be Automatically Scheduled if that is what you are looking for but running Autogen on Monday will replace what was auto-selected.
Thank you, that seems to work.
