Hi, while using the iOS Xert player for a workout with the 2inPower Rotor power meter with Oval chainrings the cadence is jumping around and is not accurate. Showing 145-205 instead of 80-100. I had this problem in zwift, changed the Powermeter connection to ANT+ instead of Bluetooth and it solved it for Zwift but can’t do that for the iOS Xert player as only bluetooth connection.
Hi Maxim. Unfortunately the app uses standard cadence BT profiles and we don’t yet support and device specific ones at the moment. Check if there is an app with the 2inPower that allows you to make any adjustments.
