What change to my fitness signature can I expect if I just keep increasing workload but achieve no break throughs?
Probably depends on your decay setting.
If Iâm on âwinter modeâ, no decay, lots of zone 2, I find my TP/LTP track up by a couple of watts per week, which seems to be borne out as correct when I eventually go for a BT.
FWIW even in winter/base I think I benefit from a BT effort at least once a month to keep some high/peak in my legs, otherwise it takes ages to snap into spring mode.
Good question @kojiro ! As you train more, we would expect that your fitness signature will increase⌠whether or not you do a FTP test or maximal effort to âproveâ it. Xert will estimate how much your signature increases with your training load based on your historical data.
@RobT Decay setting wonât matter much anymore since the latest updates to Xert - all decay methods have the âTraining Load Matchedâ function to them. Even with âSlow Decayâ setting and no BTâs notice how this userâs TP tracks upward with their Training load:
Ref: Improvements to Fitness Signature Tracking â Xert
Thanks Scott - must have missed that update. I note you can still select different / original decay options in profile: what should that be set to now, in light of the new mode? Is it still âwhatever best suits usâ itâs just that theyâve all changed a bit?
Now the Slow Decay, Optimal, & Aggressive decay will only decay to about ~5% below where we would expect your signature to be (based on No Decay). The main difference between them will be how quickly they decay to that point (aggressive will get there quickly, slow will take longer, & optimal between those two).
The âNo Decay - Training Load Matchedâ option will still track more or less exactly what we would expect your signature to be given your TL.
Excellent - thanks for the reply!
Thanks Scott.
