I signed up for Xert and imported last year of my workouts from TP. However I see that weight for all workouts remains the same. This makes Power/Weight calculations invalid. Is it possible to also import the metrics so that P/W is calculated properly for each workout over time?
Unfortunately, TrainingPeaks does not include weight in their data. You can modify your weight per activity. You may want to do that for your activities with breakthroughs to ensure your W/kg are calculated correctly for comparison purposes.
