How to manually enter threshold power
my threshold power is easily 15-20 watts to high. how can i adjust this manually?
First compare your PP and HIE to this chart to see if you are within the bell curve range for those values. [déjà vu?]
If not, consider performing a “fitness test” workout in Slope mode to validate your signature.
To make a manual adjustment to your signature view last activity details and enter the adjustment under the chart then Save(Lock). Adjustments moving forward will apply to the locked entry.
Another option is to view your last BT activity linked under your name and status stars on XO home page. Adjust your signature there and Save. Adjustments will apply based on activities recorded since the date of that BT.
thanks for your help
