The Magic Bucket field is great, but it crashes 1-15 min into every ride and only shows “IQ!”. The data field connects and works normally until it crashes. Re-adding it fixes it for the rest of the ride. However, this means stopping mid-ride every time, which is a real annoyance.
This has been reported before, but it persists and has not been resolved.
Is this a Garmin bug or a bug in the Xert data field?
Tried without effect:
A profile with only this data screen (to rule out a memory issue)
Removing and reinstalling the data field (including restarting both the device and iPhone)
I also replied to your other post.
I know this won’t help at all but I have noticed x40 is a common trait for those having issues.
Have you removed all CIQ data fields from the 840 and only installed XMB?
Some 3rd party IQ apps/fields run in background regardless of what profile is in use.
And I’m well aware the the x40 and x50 seems to have quite a lot of IQ issues.
But, I think it needs to be established if this will need a Garmin fix or an Xert fix.
is a known garmin FW issue, not specific to the magic bucket specifically but all external datafields. you should check if there is a new FW (with fix), i finally got my update over garmin express yesterday, and didn’t experience the usual issues, but that’s one ride only.
A brief update. Uninstalling all datafields apps. And then adding first magic bucket, then Xert dashboard has not resulted in any crashes. Tried to add Xert Training Advice, but it caused lag on the Edge 840 unit, and I therefore decided to not install it.
The issue therefore could be either Komoot or Xert training advisor. For now, I don’t need any of those.
