I am using the 920XT but i cant change the MPA Value in there. There is a default value 1200W i cant update. there are 2 data fields in the connect IQ store. just the older one is for the 920XT. any solution?
Hi Ralf. Be sure to enter your Xert Code into the settings. Xert Code is available on the Garmin ConnectIQ page on the menu. Sometimes you may need to try Garmin Express or Garmin Connect Mobile to get the Garmin to properly store the code. You’ll know when the default value is no longer 1200W.
I got it, thank you!
