Frustration of Magic Buckets
Hi
Any idea why I have Magic Buckets all set and I’m about to leave the house when everything drops out and I get the Waiting For Targets screen? Targets were there a second a go. Thanks
Once you press start it will refetch the targets. If you did not bring your phone, that will fail. Furthermore. If you have an Edge X30 or older, it can only fetch the targets every 5 minutes. 231 on the screen indicates the number of seconds until the next fetch (counting down from 300). Newer devices can fetch more frequently.
Thanks for that. This is the 1030 plus. I always take my phone and didn’t realise the 231 was counting down. Appreciate the explanation :+1:
You can start your ride while the 300 sec timer is counting down. When the fetch is successful any XSS you’ve accumulated will be applied to the day’s targets.
The Beta version improves upon the initial fetch routine if you’d like to try that.
Otherwise the next update will include that change.
