Force the use of hart-rate re power
Due to failing power meter, I would like the system to use hartrate data for a single activity, is this possible?
Do I have other options?
Thanks!
The only way to do this is to export the .fit fil, strip out the power, and re-upload.
fitfiletools.com is a great site for modifying & editing fit files :slight_smile:
ok, tx.
I tried, but unfortunately Xert does not handle is well. It does recognise as a hart-derived activity but only 10 XSS for a 4 hour ride. Never mind, I will work around it one way or another. I found adding manual XSS difficult in the past.
Otherwise Xert is a good platform, thanks for your effort and time.
Just to be fair, I managed to add manual xss. No hart-rate but better than nothing. Thanks again for excelent platform.
Hmm. We assume that when Cadence = 0, then you’re coasting, so you can’t be accumulating XSS. So if the power meter died and the file is full of 0 rpm cadence data, that could maybe explain what you’re seeing.
If you don’t mind, try also stripping the cadence data as well and see if that improves things.
