Is there a way to get a speed reading, when using the IQ App workoutplayer? The App does pick up the cadence, but doesn’t show any speed reading. The status page says, the app gets speed via gps although it is turned off. When coupling the neo with edge and riding indoors, i usually get speed readings. Am I doing something wrong?
Don’t think so. If GPS is off, then speed should be coming from trainer’s ANT interface. Have you change the App’s wheel diameter settings (using GCM) by chance?
I had set the wheel circumreference to 2096mm. After trying to connect for an hour, i de- and reinstalled the app on the edge. Now it’s working fine. Thank you for your reply and keep up the good work!
